@dateval does not convert alpha series to a date series
mamo
Postby mamo » Wed Mar 25, 2020 5:20 am
Dear Eviewers,
I use Eviews 11 Sept 2019 built 64 bit.
With the attached file and applying the code below, I want to generate a new series named "newdate" from the existing alpha-series named "date" with the values "Sat Feb 15 2020", "Sun Feb 16 2020", "Mon Feb 17 2020", ....
But I get only NAs.
Can you help me what the error is?
Best,
mamo
series newdate=@dateval(date, "Wdy Mon DD yyyy")
dates.wf1
(12.66 KiB) Downloaded 771 times
mamo
Re: @dateval does not convert alpha series to a date series
Postby mamo » Wed Mar 25, 2020 5:59 am
I solved the issue, and the solution suggests that there is a bug in the function @datevalue
First removing the three-letter weekday abbreviation at string positions 1-3 from the date string before applying @datevalue:
series newdate=@dateval(@mid(date,5), "Mon DD yyyy")
yields the expected result.
It seems that the double day specification - the three-letter weekday abbreviation at the beginning and the two-digit-day-of-months at string positions 9-10 - confuses @datevalue.
Prbly sth to consider for future updates of EVIEWS.
Best, mamo
EViews Matt
Postby EViews Matt » Wed Mar 25, 2020 12:35 pm
This is indeed a bug, and will be fixed in the next EViews patch.
