include command with string variable
Elderfield.A
Postby Elderfield.A » Wed Dec 18, 2019 3:35 pm
Can the include command be used with a string variable?
for example
include "C:\Some folder\some other folder\a_program.prg"
Works but
string filepath = "C:\Some folder\some other folder\a_program.prg" include filepath
doesn't work if the file path isn't the same as the current working directory.
Adam
Re: include command with string variable
Postby EViews Gareth » Wed Dec 18, 2019 3:49 pm
It cannot.
Includes are performed as a pre-processor step, and as such are done before any % or string variables are available.
You can use Exec instead, although that might not give you exactly what you want.
Elderfield.A
Postby Elderfield.A » Wed Dec 18, 2019 4:21 pm
No, I don't think exec will work unless I define my file paths as string variables?
In any case, thanks.
