I have a simple question.
Is the Excel addin for Eviews 11 the same for Eviews 10?
Best regards.
Re: Excel addin for Eviews 11
For the most part, yes. The EViews 11 Excel add-in will have a different icon image used for the "Get Data" button, but other than that, they should be the same.
Our Excel add-in uses the EViews Oledb Provider that is installed and registered by either EViews 10 or 11. Whichever one was last registered (that matches the bit-ness of your Office) is the one that is used. So if you have EViews 10 32-bit and EViews 11 64-bit, and you're using Excel 32-bit, Excel will try to use the Oledb Provider from EViews 10 32-bit, since that one matches the bitness of Excel.
