graph options gridcolor in programme code yields error
mamo
Postby mamo » Wed Dec 11, 2019 3:39 am
Dear Eviews team
I use Eviews 11, 17 Sept 2019 Built, 64 bit
The example programme below yields an error for the gridlines option.
This used to work with Eveiws 10, and the programme line is exactly the one which produced by the command capture when adjusting the gridcolor manually. So, this seems to be a bug.
Best,
mamo
wfcreate a 2000 2010 series x=nrnd freeze(gr) x.line show gr gr.options gridcolor(160,160,160) ' Error message: "illegal color setting 160"
Re: graph options gridcolor in programme code yields error
Postby EViews Jason » Wed Dec 11, 2019 9:46 am
We will get it fixed in the next patch. If you cannot wait till the patch is released use:
gr.options gridcolor(@rgb(160,160,160))
NOTE: The @rgb() function/format is meant to supercede to old specification of 3 rgb colors. The old format will continue to be supported for legacy options such 'gridcolor' but we cannot guarantee it will be for any future options.
mamo
Postby mamo » Thu Dec 12, 2019 6:34 am
Many thanks for the quick reply, this helps. I will use the @rgb function then.
Best, mamo
