Problem with Import(type=raw)
linkan
Postby linkan » Wed Nov 20, 2019 1:38 am
I have a problem with Import(type=raw) with some text files we get from our sub contractor. To show the problem I have created 2 files. First data.txt which is a shorted down version (with changed numbers) of the file we get from our sub contractor. Second is data2.txt, which is the same file, but in each row a space is added arround column 80.
We use code similar to
Import(type=raw) .\Data.txt names=bhus01, fieldtype=fixed, rformat=1
to imort the data. Each column is its own variable.
The part that I have had problems with is the first columns. In this specific case it is columns 2 and 6 that gets strange. While the other columns get 1,2,3,4,5,6,7,8,9,0,1,2,3,4,5 as their values (as expected), columns 2 and 6 skips the values 8 and 9, and puts two NA values at the bottom instead (1,2,3,4,5,6,7,0,1,2,3,4,5,NA,NA).
I have not been able to find exactly what the problem is, but for example adding a column in the middle often seems to make it work. Deleting one column in the middle sometimes works, but sometimes it skips 1 value instead. We have tested this on both Eviews 10 and 11 on 4 different computers, all getting the same result. Since adding/deleting columns in the middle of the rows changes the result, and since we can't find any strange symbols at end of line, only linefeed and carige return (checked with hex-editor as well), it seems like it isn't the file that is the problem, but a bug in Eviews Import.
testimport.prg
(2.59 KiB) Downloaded 713 times
data2.txt
(1.89 KiB) Downloaded 714 times
data.txt
(1.87 KiB) Downloaded 711 times
Re: Problem with Import(type=raw)
Postby EViews Jason » Thu Nov 21, 2019 10:45 am
I couldn't replicate the reported behavior. Using your program series 'bhus01' on pages individ and individ2 are identical where the values are 1,2,3,4,5,6,7,8,9,0,1,2,3,4,5.
The first thing I would do is check that your copies of EViews are up to date. Select Help->EViews Update to confirm.
Assuming updating does not fix the problem and for a quicker response email me at jason@eviews.com.
