Hints for "for" loop in nested hierarchy
Chthoniid
Postby Chthoniid » Tue Oct 22, 2019 7:36 pm
My data is organised as following hierarchy:
1843 subjects, each with 9 sets of questions across 4 alternatives.
For each set of 4 alternatives I want to find the highest value of one variable (if it is present). So everything I do I want to do on each set of 4 alternatives.
for !i=1 to 1843
for !j= 1 to 9
for !k=1 to 4
smpl if !i=id and !j =survey_qnumber and !k=alternative
smpl if type1=1
series wildp=@maxsby(price, alternative)
However, this returns the highest price across all 1843 rows, not the highest price in each subset of 4 alternatives. I know my programming is pretty rusty, so if anyone can identify what I'm doing wrong and what would work instead, I'd love a few hints.
Re: Hints for "for" loop in nested hierarchy
Postby EViews Gareth » Tue Oct 22, 2019 9:12 pm
You'll need to be more specific as to how the data are set up in EViews.
Does not describe data in EViews.
Chthoniid
Postby Chthoniid » Wed Oct 23, 2019 1:49 pm
Ah, sorry.
I import the data from a csv file, as unstructured data.
Screenshot added.
ID is the highest level, this branches into sruvey_qnumber (1-9) and this branches into 1-4 alternatives.
My goal is to collate and aggregate each of the 4 alternative rows into one row, using select variable values across the 4 rows. So for instance, I want the maximum price (column w) for each type 1 (column H) reduced to a single row of data at the end of the program.
TIA, B
Chthoniid
Postby Chthoniid » Thu Oct 24, 2019 6:22 pm
Got it all figured
