Sort panel data
pelleenglund
Sort panel data
Postby pelleenglund » Thu Sep 26, 2019 5:50 am
I wonder if one could sort panel data in Eviews by year instead of ID (see example below)? Right now I can only get all years for the first ID, then all years for the next and so on.
ID Year Series
1 1995 12
2 1995 ..
3 1995 ..
1 1996 ..
2 1996
3 1996
1 1997
2 1997
3 1997
Best regards,
Per
Re: Sort panel data
Postby EViews Gareth » Thu Sep 26, 2019 7:26 am
Not really.
You could restructure the panel as an undated panel, and then have the time and cross-section identifiers in any order you want, but then you'll lose all date functionality.
pelleenglund
Re: Sort panel data
Postby pelleenglund » Fri Sep 27, 2019 1:57 am
Thanks for ýour answer.
The reason I asked had to do with the new geomap objects. It doesn't seem to connect the map id (e.g. a municipality code) with the corresponding code in the dataset for a panel. But it works fine if you only look for one year separately.
/Pelle
Re: Sort panel data
Postby EViews Glenn » Wed Oct 30, 2019 11:54 am
It should work. Can you give us a bit more detail on precisely what you are doing, what you expect, and what you are seeing.
Thanks.
