good morning, I have just started using EViews 7 and I am trying to use an old code, that was working with EViews 4 until a few days ago, to iterate out of sample forecasting; it worked with EViews 4 but now I get an error. The code is:
for !horizon=1 to cont
equation eqopuno.ordered tre c esog1(-1) esog2(-1)
eqopuno.makemodel(modelopuno)
eqopuno.makelimits
modelopuno.solve(n=f)
What is strange is that the model doesn't work but if I create the equation from "quick" and then manually create the model it works, and even if I use a code to create an equation without specifying the name:
ordered tre c n1ortog(-1) tre(-1) eynorm(-1) rit1(-1) (vix(-1)-1)
then I can create the model manually, but if I estimate the equation with:
then I can not create the model neither manually...
I hope someone can help me, thanks!
ordered probit & make model
Re: ordered probit & make model
Hard to help without knowing what the error is.
"the model contains errors and could not be compiled in "do_modelopuno solve"
in the model I find: "err @identity is not a genr or series expression function in: ".eqopuno"
but if I create with the code an equation with the same time series (endogenous and exogenous) but with no name (ordered tre exogenous1(-1), exogenous2(-1)) and the create the model manually, it works and i geto no error messages, so the problem is not in the series but in the instruction wich gives the name to the equation it is estimating...
Looks like a bug in EViews, I'll investigate.
thanks a lot!
Latest patch should fix it for you.
it works with the new patch, thank you!!
Hi, I couldn't download the patch above. isn't it available anymore? thanks!Latest patch should fix it for you.
Try reloading that page.
