@wlookup no more in alphabetical order
johansamuelsson
Contact:
Postby johansamuelsson » Mon Sep 02, 2019 9:56 pm
In Eviews 11 @wlookup don't returns the string list of the selected objects in alphabetical order, which was the case in Eviews 10. This can cause some major problems, at least for us.
If I run the code below in Eviews 11 then the string "a" is "A3 A2 A4 A1", while the same string in Eviews 10 (more correctly) is "A1 A2 A3 A4"
wfcreate u 1 string a1 string a2 string a3 string a4 string a = @wlookup("*","string") show a
Is it possible to adjust this?
Eviews 11: Enterprice Edition - Aug 19 2019 build
Eviews 10: Enterprice Edition - Apr 15 2019 build
Regards Johan
Re: @wlookup no more in alphabetical order
Postby EViews Gareth » Mon Sep 02, 2019 10:43 pm
We’ll look into it, but if your code requires a list be sorted, it is probably safest to sort the list.
johansamuelsson
Contact:
Postby johansamuelsson » Tue Sep 03, 2019 4:31 am
Thank's Gareth
We will try to sort the strings in the future. However, we have a lot of current code so we would appreciate if @wlookup could be fixed.
Regards Johan
