Hi there,
I understand that @strdate returns a string list corresponding to each element in workfile.
Is there a similar function available to obtain each element in the the current sample ?
Many thansk,
Mara
@strdate for current sample
EViews Matt
Re: @strdate for current sample
@strdate creates an alpha series rather than a lone string. If you want a single string containing all the sample's dates, you can use @strdate to create date strings for all observations, then use stom() to extract only the date strings for the current sample into an svector, and finally use @wjoin to combine the elements of that svector into a single string.
maragloria
Thanks for the prompt reply!
