I noticed a small issue with creating the output of IRFs when using the code to produce them. The capture dialog box does not give the option correctly for the 'multiple graphs' setting. It will output neither a t, g, or m to specify what output it should produce, when it should give an m.
Table or combined graph does result in the dialog box producing the t or g option needed.
Eviews 9.5.
Regards,
Matt
Generating IRF graph/table from capture EV9.5
Re: Generating IRF graph/table from capture EV9.5
The default is m, so the m option is not needed.
