ADF test on multiple variables and saved in a table
New_user_ds
Postby New_user_ds » Wed Oct 24, 2018 6:43 am
I seek to improve the efficiency of performing ADF tests on group of variables.
I want the eviews to test each variable in the the group and report back t-stat or pvalue (if possible) in a matrix corresponding to the variable name.
There would be two ADF tests: (1) including constant and (2) constant and trend.
Hence there would be a 2x6 matrix.
Currently my code is as follows, and please tell me where it's wrong with the necessary adjustments.
group unit_root x1 x2 x3 x4 x5 x6 table(6,6) unit_root_results for !i=1 to unit_root.@count %name = unit_root.@seriesname(!i) uroot(adf, const, dif=0, save=root_c) {%name} uroot(adf,const,trend, dif=0, save=root_c) {%name} unit_root_results(1,1+!i)=%name next
Thanks.
Re: ADF test on multiple variables and saved in a table
Postby EViews Gareth » Wed Oct 24, 2018 7:07 am
needs to be grabbing the correct element out of root_c, not %name.
New_user_ds
Postby New_user_ds » Fri Oct 26, 2018 2:51 am
With what line of code do I need to realise that? I think the code up until " uroot( adf, const, dif=0, save=root_c) {%name] " is correct. What is the code to ensure that?
group unit_root log(rc) log(pedy) log(psh) log(ph) log(dep) rcb table(6,6) unit_root_results for !i=1 to unit_root.@count %name= unit_root.@seriesname(!i) uroot( adf, const, dif=0, save=root_c) {%name} uroot(adf,const,trend, dif=0, save=root_c) {%name} unit_root_results(1,1+!i)=%root_c next
serdarbhr
Postby serdarbhr » Sun Dec 09, 2018 10:59 am
I am totally starter on eviews
ı have multiple series and I d like to make adf unit root test
do you have any recommendation for me
thanks in advance
