programs for forecast combination
cecelia
Postby cecelia » Wed Sep 05, 2018 4:07 am
Hi there
I am struggling to write programs for forecast combinations. The built-in function 'forecast averaging' only considers one combination, which is to combine all of the individual forecasts. I need to consider all possible combinations of the individual forecasts. For example, if there are 9 individual forecasts, any possible 8, 7, ..., 2 combinations require looking at, ending with 502 possible combinations in total. And the corresponding weights need to be worked out using different weighting schemes. Have you got any insights to write such programs? I am a beginner in programming and am highly appreciated if you can provide any solutions or suggestions.
Many thanks
EViews Matt
Re: programs for forecast combination
Postby EViews Matt » Wed Sep 05, 2018 10:34 am
One of the core sub-problems you have is generating all combinations of a certain size. Here's an example EViews program that generates such combinations, storing them as indices in a vector. Since you're generating combinations of multiple sizes, you can surround the relevant code in another loop to iterate through the sizes.
logmode +l create u 1 ' Parameters for the combination, modeled after n-choose-k, C(n, k). !n = 5 !k = 3 ' Initialize the first combination. vector(!k) combination for !i = 1 to !k combination(!i) = !i next while combination(!k) < !n + 1 ' Do your work evaluating the combination. ' As an example, we'll just display the indices that represent the combination. for !i = 1 to !k %tmp = @str(combination(!i)) logmsg %tmp next logmsg "---" ' Advance to the next combination !j = !k while !j > 1 and combination(!j) = !j + !n - !k !j = !j - 1 wend !s = combination(!j) + 1 for !i = !j to !k combination(!i) = !s !s = !s + 1 next wend
cecelia
Postby cecelia » Fri Sep 07, 2018 7:36 am
Hi Matt
Thank you very much for your reply!
My work does need to evaluate the forecasting performance, which is to get the percentage of the superior combinations. I will study the code you provide first, and think about the follow-on work afterwards.
Many thanks!
