Copy (merge) from one Aremos database to another
mmiller2
Postby mmiller2 » Wed Aug 22, 2018 7:57 am
There seems to be an issue when I try to copy (with merge option) series objects directly from one Aremos database to another. The code below demonstrates that the additional observation in series x from abank2 is not properly copied and merged with existing series x in abank1. Would you be able to fix this in the next patch?
db(type=aremos) abank1.bnk db(type=aremos) abank2.bnk wfcreate(wf=work, page=a) a 1901 2099 smpl 1968 2016 ' create x in abank1 genr x = 1 copy(o) x abank1::x delete x close abank1 smpl 2017 2017 ' create x in abank2 genr x = 2 copy(o) x abank2::x delete x close abank2 smpl @all ' copy and merge x from abank2 to abank1 dbopen(type=aremos) abank2.bnk dbopen(type=aremos) abank1.bnk copy(m) abank2::x.a abank1::x.a fetch(db=abank1) x smpl 2016 2017 x.sheet ' correct result should be 1 2
Re: Copy (merge) from one Aremos database to another
Postby EViews Gareth » Wed Aug 22, 2018 8:56 am
Documentation bug. The merge option does not apply to database->database copies.
