Create a comma separated string with quotes?
xprimexinverse
Contact:
Postby xprimexinverse » Sun Aug 12, 2018 11:10 am
Hi everyone,
I would like to use the import command in an automated way and to do this I need to pass in the string values for the column head names as options.
For example, below I pass three strings into the colheadnames option of the import command.
colheadnames=("Name","Unit_code","Unit_description")
However, the above example is hard coded and I don't want to do this. What I'd like to do is pass all of these individual strings in as a single string variable (or single argument).
For example, I'd like to be able to do this:
%colheadnames = "Name","Unit_code","Unit_description" colheadnames = (%colheadnames)
Any ideas?
Thanks,
Graeme
Last edited by xprimexinverse on Sun Aug 12, 2018 11:24 am, edited 1 time in total.
Re: Create a comma separated string with quotes?
Postby EViews Gareth » Sun Aug 12, 2018 11:12 am
%colheadnames = """Name"",""Unit_code"",""Unit_description"""
xprimexinverse
Contact:
Postby xprimexinverse » Sun Aug 12, 2018 1:14 pm
Thanks very much, Gareth! :D
Works a charm!
