How to check for existence of an URL?
mamo
Postby mamo » Tue Jul 31, 2018 12:21 am
Dear Eviewers,
I use Eviews 10+.
Would anybody have a suggestion how to check for the existence of an url?
(for instance: excel file with US GDP data at the BEA, "https://www.bea.gov/national/xls/gdplev.xlsx")
It seems that the Eviews-function "@fileexist" does not work with urls.
Best, mamo
Re: How to check for existence of an URL?
Postby EViews Gareth » Tue Jul 31, 2018 6:49 am
Try opening it and if it fails, it doesn’t exist?
mamo
Postby mamo » Tue Jul 31, 2018 7:49 am
Well I am looking for sth which can be applied in a program, for instance
%url="https://www.bea.gov/national/xls/gdplev.xlsx"
if @urlexist(%url) then
'do something
else
'do something else
endif
Postby EViews Gareth » Tue Jul 31, 2018 9:04 am
setmaxerrs 2 wfopen "https://www.bea.gov/national/xls/gdplev.xlsx" if @errorcount>0 then 'do something else ' do something else endif
mamo
Postby mamo » Wed Aug 01, 2018 3:56 am
Many thanks, this is a workable patch-around.
For completeness and for whom it may be useful, I provide below a subroutine with improved code (disabling also log-messages, and resetting the error counter).
However, this work-around requires reading in the respective file linked to by the url. If the file is large, this wastes considerable computing time.
Hence, I'd like to suggest to the EVIEWS team to consider implementing a more efficient approach in a function named like '@urlexist' in upcoming versions.
mamo
' %url="http://www.euklems.net/TCB/2017/US_output_17i.xlsx" ' smaller file; routine works reasonably fast %url="https://www.bea.gov/national/xls/gdplev.xlsx" ' large file; routine take a lot of time for a simple check! !checkurl=0 call checkurl(%url, !checkurl) statusline !checkurl subroutine checkurl(string %url, scalar !check) setmaxerrs 2 logmode -e !check=0 wfopen %url if @errorcount=0 then !check=1 wfclose endif clearerrs setmaxerrs 1 logmode 2 endsub
