Get axis range from graph object
tho_mi
Postby tho_mi » Thu Apr 19, 2018 4:46 am
Hey,
I'd like to find out which ranges EViews uses for a certain graph. Is there a way to do that? Setting the range is straightforward, but I'd like to get the ranges EViews uses. If it's not possible to get the ranges from an object, how does EViews calculate min and max? Usually it's some "nice" number and I'd like to know how EViews gets there (simple rounding isn't very flexible if you don't know the scale of the variable apriori).
Thanks in advance!
Re: Get axis range from graph object
Postby EViews Gareth » Thu Apr 19, 2018 7:44 am
graph.@axismin graph.@axismax
tho_mi
Postby tho_mi » Fri Apr 20, 2018 4:48 am
Thanks! Could you also tell me how the ranges are calculated? I'd like to know them before I plot the data.
Postby EViews Gareth » Fri Apr 20, 2018 7:30 am
Unfortunately that is a proprietary algorithm.
