Loop for find a minimun
lpando08
Postby lpando08 » Thu Apr 12, 2018 11:00 am
Hi, I have something like this. I want to create the series hdebt and ldebt outside program, but instead the value is fixed in 60 I want to vary from 10 to 100 and I want the program to find which number between 10 and 100 could minimize the SSR done by :
scalar ssrt_debt=sum_ssr_ldebt+sum_ssr_hdebt
I was trying to do it like this but it doesn't work, I do not know how make the program to give results to hdebt_10 and ldebt_10, hdebt_20 and ldebt_20, etc:
'for !x=10 to 100
'smpl if debt>!x
'series hdebt_!x=1
'smpl if debt <!x
'series ldebt_!x=1
'next
****THIS IS A PART OF THE PROGRAM (NOT COMPLETED)****
smpl if debt>60
series hdebt=1
smpl if debt<60
series ldebt=1
string grps = "h dev fixed flex open closed hdebt ldebt"
for %grp {grps} ' country/observation groupings
'running VAR and impulse responses
smpl @first 2007q4 if {%grp}=1 and {%grp}(-!lags)=1
'Choosing lag length optimally
if %lag_crit = "wald" then
var var_{%grp}.ls(noconst) 1 !maxlags {varlist}
var_{%grp}.testlags(name=waldlags_{%grp})
!flag=1
!count = !maxlags+1
while !flag
!count = !count-1
if @chisq(waldlags_{%grp}(!count,!vars+1),!vars^2) < 0.05 or !count=2 then
!lags = !count
!flag=0
endif
wend
delete waldlags_{%grp}
endif
if %lag_crit<>"none" and %lag_crit<>"wald" then
var_{%grp}.laglen(!maxlags, vname=lagtests_{%grp})
if %lag_crit = "lr" then
!lags = lagtests_{%grp}(1)
endif
if %lag_crit = "aic" then
!lags = lagtests_{%grp}(3)
endif
if %lag_crit = "sc" then
!lags = lagtests_{%grp}(4)
endif
if %lag_crit = "hq" then
!lags = lagtests_{%grp}(5)
endif
delete lagtests_{%grp}
endif
scalar lags_{%grp}_{%type}_{%lagcrit} = !lags
var var_{%grp}.ls(noconst) 1 !lags {varlist}
var_{%grp}.impulse(!imp_len, m, se=a, imp=chol, matbys=imp_{%grp}) {varlist} @ {gvar}
var_{%grp}.impulse(!imp_len, m, a, se=a, imp=chol, matbys=imp_{%grp}_a) {varlist} @ {gvar}
var_{%grp}.makeresids {residlist}
sym resid_cov_actual = var_{%grp}.@residcov
matrix resid_cov_act = var_{%grp}.@residcov
for %c {%grp}
for !j = 1 to var_{%c}.@neqn
vector(!j) ssr_{%c}(!j)= var_{%c}.@ssr(!j)
vector sum_ssr_{%c}=@sum(ssr_{%c})
close var_{%grp}
Thank you very much!
EViews Matt
Re: Loop for find a minimun
Postby EViews Matt » Thu Apr 12, 2018 12:59 pm
It sounds like you're trying to create a pair of dummy variables. You can do that directly without setting a sample.
for !x = 10 to 100 step 10 series hdebt_!x = debt > !x series ldebt_!x = debt < !x next
lpando08
Postby lpando08 » Thu Apr 12, 2018 1:32 pm
But how I can report for example the vector sum_ssr_hdebt_10, sum_ssr_hdebt_20? I can't see them. Where I have to use !x? when I define the group string grps= "h dev fixed felx open closed hdebt_!x ldebt_!x"
like this?
string grps = "h dev fixed flex open closed hdebt_!x ldebt!x"
for %c {%grp}
EViews Matt
Postby EViews Matt » Thu Apr 12, 2018 3:37 pm
Sure, you can add them to your string of groups. Let the for loop do the work of adding the twenty new names...
string grps = "h dev fixed flex open closed" for !x = 10 to 100 step 10 series hdebt_!x = debt > !x series ldebt_!x = debt < !x grps = grps + " hdebt_" + @str(!x) + " ldebt_" + @str(!x) next
