Dear users,
I have a panel workfile with a sample of 31 cross-sections and 500 time periods. I would like to run a single regression for each crossid individually.
my cross section variable is "ID" which has values between 1 and 31. I uploaded the data correctly, having variables stacked over each ID from t=1 to T.
I would like to get a equation estimate for each cross id separately (which contain the t oberservations) Y = C + X1 + X2 + X3. and i would store the regressions as linreg1, linreg2,..., linreg31
I tried:
for !i=1 to 31
if @crossid=!i
equation linreg{!i}.LS Y X1 X2 X3
endif
But I get the error term:
Syntax error in control statement in "IF @CROSSID=1".
Can any one help me? many thanks in advande!
Best
perform a regression for each crossid individually in a panel workfile
Re: perform a regression for each crossid individually in a panel workfile
Try
for !i=1 to 31
smpl if @crossid=!i
nextRe: perform a regression for each crossid individually in a panel workfile
Great thank you so much! Best
fatihtekke
Dear Gareth,
I would like to ask a follow up question for this post. I used the code and it is working. Thanks for that.
However, I have like 1200 crossid and need to collect the estimation betas and create a matrix(new variable) by 1200x1
I wonder if you are able to help me by adding lines to the code above.
