Panels: getting date of earliest non-na in variable for a specific cross-sectional unit
mamo
Postby mamo » Wed Feb 21, 2018 8:07 am
Dear all,
I amusing Eviews 9.5 Dec 16 built.
Two questions, both assuming that one is working with a panel workfile:
1) Is there a straightforward way of assigning the number of cross sectional units in a panel workpage to a scalar variable ?
2) Is there a straightforward approach of finding the date of the earliest non-missing value in a series for a specific cross sectional unit? One possible approach is implemented in the subroutine "getearliest" in the program listed below. However, it looks to me unnecessarily complicated. Any suggestion for a more straightforward approach much welcome.
Kind regards, mamo
'create some data wfcreate q 2000 2017 2 series x=nrnd 'create NAs in x until 2004Q3 for the 2nd cross sectional unit smpl @first 2004Q3 if crossid=2 x=na smpl @all !notnadate=NA 'get the date of the earliest available non-mising value in x for the 2nd cross sectional unit call getearliest(x, "crossid", "2", !notnadate) 'show in the statusline the earliest non-missing date for the 2nd cross sectional unit %notnadate=@datestr(!notnadate, "YYYY[Q]Q") statusline %notnadate subroutine getearliest(series v, string %crossidentifier, string %cid, scalar !dat) 'gets the date of the earliest available non-mising value in v cross sectional unit labelled %cid ' in the series or alpha %crossidentifier identifying the cross secional units 'and writes into the string variable "%dat" %oldsmpl=@pagesmpl if {%crossidentifier}.@type="SERIES" then smpl @all if {%crossidentifier}={%cid} else if {%crossidentifier}.@type="ALPHA" then smpl @all if {%crossidentifier}=@stripquotes(%cid) endif endif vector(1) _$ndates series _$$ndates=@max(@cellid, @all) stom(_$$ndates, _$ndates) !t1=@ifirst(v)-(_$ndates(1)*(@floor(@ifirst(v)/_$ndates(1)))) delete _$ndates _$$ndates series _$t2=@date(!t1-1) vector(1) _$t3 stom(_$t2, _$t3) !dat =_$t3(1) delete _$t2 _$t3 smpl {%oldsmpl} endsub
Re: Panels: getting date of earliest non-na in variable for a specific cross-sectional unit
Postby EViews Gareth » Wed Feb 21, 2018 9:03 am
1)
series _cross = @crossid scalar numcross = @max(_cross)
2)
smpl if @crossid=3 string date = @otod(@ifirst(y))
