EPS figures in LATEX - something wrong with fonts
Posted: Sun Jan 21, 2018 11:58 am
by tvonbrasch
I have made the following graph in Eviews
I have saved the graph in EPS format using the code
_graph.save(t=eps) ..\graphs\graph_productivity
When loading the EPS file in LATEX, i get the following picture:
Why is this happening with the fonts?
Re: EPS figures in LATEX - something wrong with fonts
Posted: Sun Jan 21, 2018 12:36 pm
Looks much better! Keep it!
Posted: Mon Jan 22, 2018 8:28 am
by tvonbrasch
:D
For some reason, the font Arial works fine.....
Posted: Mon Jan 22, 2018 9:09 am
The issue may be which fonts are used in the eps and whether they are embedded in the LaTex document. You might check to see if you can adjust LaTex to be sure it's including the fonts coming out of EViews.
Posted: Mon Jan 22, 2018 10:44 am
by tvonbrasch
great, thanks, i will see if that fixes the problem
thomas
Posted: Wed Aug 11, 2021 6:58 am
by tvonbrasch
I have a new and related issue with EPS files. The graph I have made looks like this in EViews:
but, when saving it in EPS, it looks like this:
The blue circles do not look good...
Attached is the EViews workile with the graph object. Can you please help me save this graph in EPS format in a way that it looks similar to the EViews graph object?
t
Posted: Wed Aug 11, 2021 7:06 am
by tvonbrasch
if I change the fonts to times new roman, I get the EPS picture:
but the blue circles are still not looking good ...
t
Posted: Wed Aug 11, 2021 9:49 am
by EViews Jason
It will be fixed in the next patch. There is an issue when calculating the radius of a circle in EPS.
Posted: Wed Aug 11, 2021 11:24 am
by tvonbrasch
great, thanks!
Posted: Thu Dec 09, 2021 9:33 am
by tvonbrasch
I now have a similar problem with boxplots,
picture when including the eps picture in a latex file:
2021-12-09 17_27_37-hovedfil - PDF-XChange Editor.png (21.46 KiB) Viewed 20795 times
whats happening with the black circles? this is how it is supposed to be, i.e. the picture from EViews or when stored directly in png-format:
Can you please take a look at this?
