EPS figures in LATEX - something wrong with fonts
Postby tvonbrasch » Sun Jan 21, 2018 11:58 am
I have made the following graph in Eviews
I have saved the graph in EPS format using the code
_graph.save(t=eps) ..\graphs\graph_productivity
When loading the EPS file in LATEX, i get the following picture:
Why is this happening with the fonts?
Re: EPS figures in LATEX - something wrong with fonts
Postby EViews Gareth » Sun Jan 21, 2018 12:36 pm
Looks much better! Keep it!
Postby tvonbrasch » Mon Jan 22, 2018 8:28 am
:D
For some reason, the font Arial works fine.....
Postby startz » Mon Jan 22, 2018 9:09 am
The issue may be which fonts are used in the eps and whether they are embedded in the LaTex document. You might check to see if you can adjust LaTex to be sure it's including the fonts coming out of EViews.
Postby tvonbrasch » Mon Jan 22, 2018 10:44 am
great, thanks, i will see if that fixes the problem
thomas
Postby tvonbrasch » Wed Aug 11, 2021 6:58 am
I have a new and related issue with EPS files. The graph I have made looks like this in EViews:
but, when saving it in EPS, it looks like this:
The blue circles do not look good...
Attached is the EViews workile with the graph object. Can you please help me save this graph in EPS format in a way that it looks similar to the EViews graph object?
t
eps.wf1
(496.03 KiB) Downloaded 794 times
Postby tvonbrasch » Wed Aug 11, 2021 7:06 am
if I change the fonts to times new roman, I get the EPS picture:
but the blue circles are still not looking good ...
t
Postby EViews Jason » Wed Aug 11, 2021 9:49 am
It will be fixed in the next patch. There is an issue when calculating the radius of a circle in EPS.
Postby tvonbrasch » Wed Aug 11, 2021 11:24 am
great, thanks!
Postby tvonbrasch » Thu Dec 09, 2021 9:33 am
I now have a similar problem with boxplots,
picture when including the eps picture in a latex file:
2021-12-09 17_27_37-hovedfil - PDF-XChange Editor.png (21.46 KiB) Viewed 20784 times
whats happening with the black circles? this is how it is supposed to be, i.e. the picture from EViews or when stored directly in png-format:
Can you please take a look at this?
