Hi all,
we have upgraded recently to EViews 10 (64bit) Standard Edition (Perpetual, Windows) and are getting the following message in the Excel Add-In:
Unable to obtain license: licensing has not been configured on this machine
Can someone please advise how we can fix this error?
Thank you very much and kind regards,
Peter
"Get Data" in Excel Add-In with EViews (64bit) 10 not working
- eviews10_get_data.png (7.89 KiB) Viewed 14617 times
Re: "Get Data" in Excel Add-In with EViews (64bit) 10 not working
Two things to check:
1. Make sure you have the latest EViews 10 patch installed.
2. Run EViews and type in the command "REGCOMPONENTS" then click the "Yes(All)" button to perform a complete re-registration.
If you still run into this issue, then it's likely a previous 32-bit EViews installation that has been removed that is causing the issue. To resolve this, either install EViews 10 32-bit (which you can do with the same serial on the same machine) or download the following zip file and run the contained REG file (just double-click it) to clear your registration of all previous EViews registrations -- then re-do step 2 above to re-register everything. Restart Excel and try the add-in again.
Hi Steve,
with your .reg file and execution off "REGCOMPONENTS" ("Yes(All)") we could solve the issue.
Thank you very much for your help.
Kind regards,
Peter
Kind regards,
Peter
