Adding Titles to Graphs
BCNAV
Postby BCNAV » Thu Nov 09, 2017 12:14 pm
Hi again,
I am using
%vars="ovr_ecu_m11 ovr_ecu_m14 ovr_ecu_m22 ovr_ecu_m23 ovr_ecu_ktk ovr_ecu_oth" There are many variables here...just a sample for posting spool a_graphs !count=1 for %series {%vars} freeze(mode=overwrite,{%series}_gr) {%series}_hf.line {%series}_gr.draw(shade, bottom,color(ltgray)) 2017.10 2019.12 {%series}_gr.draw(shade, bottom,color(orange)) 2008.01 2009.03 {%series}_gr.draw(shade, bottom,color(red)) 2000.11 2004.12 {%series}_gr.addtext(t) Monthly {%series} {%series}_gr.addtext(b) "Red = Sept 11th Effect, Orange = Recession, Grey Shading = Forecast Period" {%series}_gr.addtext(l) "Charging Units" a_graphs.append {%series}_gr if !count<=9 then a_graphs.name untitled0{!count} {%series} else a_graphs.name untitled{!count} {%series} endif !count=!count+1 {%series}_gr.save(t=png,d=300,c) R:\Eviews\Graphs\ARIMA\{%series}_hf next
I some how would like to customize:
I would like the graph title to be: Monthly Custom Variable Text
so for variable ovr_ecu_m11 it would be Monthly OVR-M11
Is there a way to pass the OVR-M11 as part of the loop, or is there a way to add in
%titlenames="OVR-M11 and so on for each variable"
This would make output a bit nicer.
Thanks!
Re: Adding Titles to Graphs
Postby EViews Gareth » Thu Nov 09, 2017 1:22 pm
If the individual series already have nice display names then it is a bit easier, but assuming they don't you could just do something like:
%vars = "ovr_ecu_m11 ovr_ecu_m14 " '..... %nicevars = "OVR-M11 OVR-M14" '.... for !i =1 to @wcount(%vars) %series= @word(%vars, !i) %nicevar = @word(%nicevars, !i) 'do stuff here next
BCNAV
Postby BCNAV » Thu Nov 09, 2017 1:36 pm
If I have displaynames setup how can I use them in
Postby EViews Gareth » Thu Nov 09, 2017 1:44 pm
%title = "Monthly " + {%series}.@displayname {%series}_gr.addtext(t) {%title}
BCNAV
Postby BCNAV » Thu Nov 09, 2017 1:50 pm
Perfect!!
Cheers
