Command to put smpl into VAR or equation
Postby startz » Tue Sep 26, 2017 9:43 am
This is not the deepest question I have ever asked...
How do you put a smpl into a VAR (or equation) or into the forecast box using commands?
Re: Command to put smpl into VAR or equation
Postby EViews Gareth » Tue Sep 26, 2017 9:44 am
You don't.
You set the workfile sample, issue the command, then reset the workfile sample (if required).
Postby startz » Tue Sep 26, 2017 9:46 am
Aha! That's why I couldn't find the answer in the Help system. :)
