Equation view ommitted-variable-test: mistake in the reporting
mamo
Postby mamo » Thu Aug 31, 2017 5:19 am
Dear Eviews team,
I use Eviews 9.5 Dec 2016 built.
There is a mistake in the reporting of the equation view for the omitted variable test.
Let X be the variable to be tested for omission. The report view would say:
Null hypothesis: X are jointly significant
But it should be:
Null hypothesis: X are not jointly significant
(Note: the corresponding line in the view for the redundant-variable-test is correct)
See example program below.
Best, mamo
wfcreate a 2000 2016 series x1= nrnd series x2= nrnd series y=2+0.5*x1-2*x2+nrnd equation eq1.ls y c x1 equation eq2.ls y c x1 x2 2nd line in the following view of the omitted variable test is wrong eq1.testadd x2 '2nd line in the following view of the redundant variable test is ok eq2.testdrop x2
Re: Equation view ommitted-variable-test: mistake in the reporting
Postby EViews Glenn » Tue Sep 05, 2017 10:53 am
Thanks. Sorry about the inconvenience.
