Forecasting Variance with GARCH models
10dechile
Postby 10dechile » Thu Aug 03, 2017 2:59 pm
Hello everybody,
I’m working with monthly copper returns (1990-2016) and the purpose is to obtain variance forecasts of the next month in a rolling windows framework of 1 step. My In-sample data takes returns since 1990M02 to 2006M11, so the out-sample data covers 2006M12 to 2016M11.
The problem is that obtained forecasts differ around ten times the monthly observed variance (which I defined commonly as the mean of quadratic difference between daily returns and the average of these within the month).
I programmed it, since I’m combining the garch model (with variance regressors) with a genetic algorithm. Both this and the GARCH(1,1) model exhibit the problem mentioned above.
Does someone know why that happens? I attached both files if it helps. I would be so grateful
Regards.
pd: I'm using Eviews 8.1 version
prg_f.prg
(8.69 KiB) Downloaded 421 times
BASE.wf1
(39.6 KiB) Downloaded 373 times
