I am trying to run a program with a large number of loops in Eviews 9.5. I've noticed that after 15 minutes of running a program file in quiet mode Eviews shows an error message. One message was saying something like "!TODAY is invalid" and the second one was "%TYPE" something...
Basically my second run was from the place where the first one was interrupted which means the code works fine. Can there be other reasons why Eviews breaks the program?
Program running interrupted every 15 minutes
Re: Program running interrupted every 15 minutes
Sounds like a coding error.
Maybe. I am mostly adapting existing codes for my own needs, but it is strange.I am running 2-step DCC Garch regressions using one of the add-ins and it works fine for say 5-10 stocks (I started with 3 stocks and then increased it to 5 and then 10; all is estimated fine). So, I thought the loop works and everything. However, once I increased the code to 50 stocks both runs it stopped on the correlation 307 or 308 or in about 15 minutes. It also works if I restart the loop from say a pair combination number 290. It just go through the 307th or 308th pair of stocks just fine until it breaks again in 15 minutes time or on the next 600th correlation or so.Sounds like a coding error.
Now I've tried it on my home PC. I've got "!TODAY is not defined" message on stocks pair number 126, after around 6 minutes. Can it be because I am using EViews via Jukebox, an app that my Uni supplies so everyone has a remote access to all programs purchased by the Uni? Also I have a Mac at home and I am using Parallels Desktop for Windows, while at Uni it is Windows 10 PC. Here is the code I am using (the data attached):
'create empty equation to be used inside the loop
equation eq
'counter of how many equations we have run
!rowcounter=1
'run pairwise regressions between each series
for !i=1 to 50
!rowcounter = !i
for !j=1 to 50
if !i<>!j then
equation eq{!i}.ls x{!i} c ar(1)
eq{!i}.makeresid x{!i}r
endif
'company 1
for !i=2 to 50
!rowcounter = !i
' for !j=2 to 50
if !i<>!j then
group g1{!i} x1r x{!i}r
g1{!i}.dccgarch11(unifit="GARCH",ctarget,correl,dccout,unigarch)
endif
'next
'company 2
for !i=3 to 50
!rowcounter = !i
' for !j=3 to 50
if !i<>!j then
group g2{!i} x2r x{!i}r
g2{!i}.dccgarch11(unifit="GARCH",ctarget,correl,dccout,unigarch)
endif
'next
'company 3
for !i=4 to 50
!rowcounter = !i
' for !j=4 to 50
if !i<>!j then
group g3{!i} x3r x{!i}r
g3{!i}.dccgarch11(unifit="GARCH",ctarget,correl,dccout,unigarch)
endif
'next
'company 4
for !i=5 to 50
!rowcounter = !i
' for !j=5 to 50
if !i<>!j then
group g4{!i} x4r x{!i}r
g4{!i}.dccgarch11(unifit="GARCH",ctarget,correl,dccout,unigarch)
endif
- n=5 trial dcc.wf1
- (446.25 KiB) Downloaded 491 times
EViews Matt
This is an issue with the addin. The addin attempts to access (at least) one variable that doesn't exist, !today, but doesn't immediately abort because the addin internally increases the number of allowed errors. Your program invokes the addin enough times to eventually reach the error limit and abort. Since this is an issue with the addin, you should post in the forum for the addin and hopefully the author will fix it.
