I'm trying to fill a matrix with data from a numeric series in panel format. I am fairly new at working with panel data in this manner so I do not know how to refer to the individual values within the panel series, specially because the dimension of the panel are (reporter, partner, trade_flow, comm_code, year)=(7,8,4,12,6).
The matrix contains reporters in the rows and partners in the columns. The idea is to compute a three years average of trade_value and fill the matrix with the corresponding cross-average for reporter/partner. I use group-by statitstics to compute the three year average (see below) as it needs to be by reporter-partner-tradeflow for all comm_codes in these groups .
series avg_all=@meansby(trade_value,reporter,partner,trade_flow,threeyears) ' three-years average of trade_values
Also, I am not completely sure whether I should be using a panel structure instead of a pool structure.
The other way I think this could be worked out is to move to a lower panel structure, where I only need partner, reporter and trade_flow with the values being the three year average of trade_values, so that I get rid of year and comm_code.
I attach the workfile and code for your inspection. Can you help please?
Thanks a lot in advance,
Marta
For !i=1 to m ' no. of reporters
For !j=1 to n ' no. of partners
' Not sure how to proceed from here
if threeyears=2016 then
smpl If reporter="ITA" and partner="DEU" and trade_flow="import" and comm_code=9 'then
avg(!i,!j)=avg_all
endif
Next
Next
Filling a matrix with data from panel series
- trade weights.prg
- (1.3 KiB) Downloaded 401 times
- fxtrade_weights.WF1
- (664.14 KiB) Downloaded 379 times
EViews Mirza
Re: Filling a matrix with data from panel series
I believe this should do it. I've commented the code. Should be clear.
Obviously you'll have to figure out which rep/partners are avaialble for each configuration. This, however, should be relatively easy to obtain from the code above.
smpl @all 'set full sample
stom(trade_flow,vtf) 'convert trade flow to vector
svector vtfunique = @uniquevals(vtf) 'get unique values of trade flow
%tfalpha = @wjoin(vtfunique) 'make string of unique trade flows
stom(comm_code, vcc) 'convert comm code to vector
vector vccunique = @uniquevals(vcc) 'get unique values
!rows = @rows(vccunique)
svector(!rows) vccstring 'make svector to hold string values of comm codes
'make string vector of comm codes
for !i = 1 to !rows
vccstring(!i) = @str(vccunique(!i))
%vccalpha = @wjoin(vccstring) 'make string of unique comm codes
for %i {%vccalpha}
for %j {%tfalpha}
smpl if threeyears=2016 and year=2016 and comm_code={%i} and trade_flow=%j 'set the sample of interest
stom(reporter, vrep) 'get vector of reps
svector vrepunique = @uniquevals(vrep) 'get unique values of reps
%repu = @wjoin(vrepunique) 'make string of unique reps
%repstring = @wjoin(vrep) 'make string of all reps
'do same things for partners
stom(partner, vpart)
svector vpartunique = @uniquevals(vpart)
%partu = @wjoin(vpartunique)
%partstring = @wjoin(vpart)
%reppart = @winterleave(%repstring, %partstring) 'get a mesh of all the combinations of reps and partners in the sampel of interest
'this is preliminary since reps and partners are all space delimited
'create a new string of all reps and partner combos, where reps and partners are not space delimited, but the list is space delimited
!k=1
%reppart2 = ""
while !k<@length(%reppart)
%reppart2 = %reppart2 + " " + @replace(@mid(%reppart, !k, 7), " ", "")
!k=!k+8
wend
!rows = @rows(vrepunique) 'get rows of matrix to hold avg
!cols = @rows(vpartunique) 'get cols of matrix to hold avg
%jmod = @replace(%j, "-", "") 'due to naming, we have to remove - from re-import and re-export
matrix(!rows, !cols) mavg_{%jmod}_cc{%i} 'declare matrix to hold averages for eachh comm code and each trade flow status
stom(avg_all,mavg) 'create a vector to hold all averages of interest
for %s1 {%repu}
for %s2 {%partu}
%s3 = %s1+%s2
!s4 = @wfind(%reppart2, %s3) 'search for where reppartner combo occurs in the vector mavg
if !s4>0 then
mavg_{%jmod}_cc{%i}(@wfind(%repu, %s1), @wfind(%partu, %s2)) = mavg(!s4) 'if search is successful, enter the value
else
mavg_{%jmod}_cc{%i}(@wfind(%repu, %s1), @wfind(%partu, %s2)) = NA 'if search is not available, enter NA
endif
Thanks a lot! I'm looking at it know.
Best,
Marta
Best,
Marta
