retrieving lags selected by AIC/BIC
Posted: Fri Jul 28, 2017 9:02 am
by maragloria
I'm using EViews 9.5 and doing panel cointegration estimations using DOLS and PMG/ARDL.
Is there a easy way to retrieve the lags selected by AIC/BIC using a program?
Thanks!
Re: retrieving lags selected by AIC/BIC
Posted: Fri Jul 28, 2017 9:23 am
Unfortunately there isn't an easy way to retrieve it other than by freezing the equation output into a table and parsing the results.
Posted: Fri Jul 28, 2017 1:07 pm
by maragloria
Hello Gareth,
I was doing that but wondered if there was a better way to do it.
I'm thinking of doing something else, saving the AIC to make my own comparisons. I just realised that when using panel DOLS the @aic command returns NA (eqdols.@aic). Is that normal?
Thanks again.
Posted: Fri Jul 28, 2017 1:12 pm
What's the estimation specification?
Posted: Fri Jul 28, 2017 1:32 pm
by maragloria
equation eqdols.cointreg(method=dols, lag=1, lead=1, panmethod=grouped) neerln cpieff nfa totln prodeff gdebteff
!aictemp=_eqdols.@aic
I also used the "pooled" and "w-pooled" methods (and greater number of lags & leads) to check if matters; I still got NA.
Posted: Fri Jul 28, 2017 4:16 pm
We aren't computing the log likelihood for any of the nonstationary regression models as the notion of a likelihood is problematic in some of these settings. Arguably, we could compute a measure for the non-panel DOLS as I believe this estimator is asymptotically MLE apart from estimation of some parameters that are asymptotically zero. But we didn't think people really wanted likelihoods in this setting so we didn't compute them. Further, this gets tricky when using the grouped method.
For now, for non-grouped methods, you can compute the DOLS using standard regression tools and get the likelihood from those equations, or you can take the residuals from the built-in DOLS and compute your own likelihoods.
Going forward, we'll give this issue additional thought.
Posted: Fri Jul 28, 2017 5:09 pm
by maragloria
Thank you for the reply, I'll use the residuals option.
Posted: Tue Aug 01, 2017 9:14 am
by maragloria
Hello Gareth,
I run the following code to retrieve the lags selected by AIC, using ARDL/PMG panel estimator.
The code searches for the minimum AIC.
'run ARDL/PMG estimation
!maxlagcrit=4
!mininfocrit=10
for !lagdep=1 to !maxlagcrit
for !lagexp=1 to !maxlagcrit
equation _eqardl_aic.ardl(fixed,deplags=!lagdep,reglags=!lagexp) G
if _eqardl_aic.@aic<!mininfocrit then
!bestlagdep=!lagdep
!bestlagexp=!lagexp
!mininfocrit=_eqardl_aic.@aic
endif
equation _eqardl_aic.ardl(fixed,deplags=!bestlagdep,reglags=!bestlagexp) G
I noticed the following:
- The code above selected (2,2) as the best lag with an AIC = -4.446
- EViews selected a lag length of (4,2) with an AIC of -4.315.
- However, the "model selection summary" (see graph), gives an AIC of -4.629 for the (4,2) lag lenth and -4.616 for my selected lag length of (2,2)
Why is the AIC changing from the ones presented in the estimation results to the ones in the "model selection summary"?
Is that because the model is being selected prior to the ECM re-parametration?
Thanks for your attention.
[img]
- table1.jpg (104.96 KiB) Viewed 29955 times
[/img]
[img]
- graph.jpg (45.58 KiB) Viewed 29955 times
[/img]
[img]
- table2.jpg (126.29 KiB) Viewed 29955 times
[/img]
Posted: Tue Aug 01, 2017 9:32 am
It is probably due to dropping of lags.
When performing model selection up to, say, 4 lags, each of the 4 models (1,2,3,4) have to be tested on the same sample - so you have to drop four observations at the start for each estimation.
Then if you selected 2 as the the best model you re-estimate a 2 lag model this time only dropping two observations. That means that the information criteria from the final estimation is (slightly, hopefully) different from that used during model selection.
Posted: Tue Aug 01, 2017 9:35 am
by maragloria
Got it! Thank you very much.
