dates in @elem
EviewsUser1
dates in @elem
Postby EviewsUser1 » Thu Jul 27, 2017 12:23 pm
I define the start date of the sample:
%start="1984q1"
and I want to extract a single data point for that series dat using @elem
scalar first_actual=@elem(dat,"1984q1")
but instead of using "1984q1" I would like to use %start
but that does not work. Any suggestions?
Re: dates in @elem
Postby EViews Gareth » Thu Jul 27, 2017 12:56 pm
wfcreate q 1980 2000 series dat=nrnd %start = "1984q1" scalar first_actual=@elem(dat,%start) show first_actual
jccondi
Re: dates in @elem
Postby jccondi » Fri Jun 08, 2018 10:54 am
I'm trying to do something similar. I would like to update some series to a date inputed by a program. For example, my group is like this:
serie1/@elem(serie1, %0-360)*100
Where %0 is the given date. But unfortunatelly, it doesn't work.
So, basically, what I need is to update my series taking in consideration a given period, every time I run the program. Is that possible?
EViews Matt
Re: dates in @elem
Postby EViews Matt » Fri Jun 08, 2018 11:39 am
The second argument to @elem, the date, cannot be an expression of the form you've shown. You need to create the date you want before @elem.
jccondi
Re: dates in @elem
Postby jccondi » Fri Jun 08, 2018 12:47 pm
Thanks! How can I create such date? Is there an especial element to do it in Eviews? I've already tried scalar, but it didn't work.
EViews Matt
Re: dates in @elem
Postby EViews Matt » Fri Jun 08, 2018 2:30 pm
If your "dates" are just simple observation numbers, you can create the adjusted date string simply as,
%tmp = @str(%0 - 360)
However, if you're dealing with formatted date strings, e.g., "1/1/1990", then @dateadd should be used to perform the adjustment. Since @dateadd operates on EViews' date numbers rather than data strings, some conversion to/from date numbers is also needed. For example,
%tmp = @datestr(@dateadd(@dateval(%0), -360, "DD"))
Bjellerup
Re: dates in @elem
Postby Bjellerup » Mon Feb 10, 2020 7:08 am
Hi Matt,
I'm still struggling with this. I have a workfile in quarterly format. At the start of the program file I have
%sobs="1993Q1"
and then later on I have (rebasing a series)
series p1us = pceus/@elem(pceus,"%sobs")
but it doesn't work. I thought I knew what to do using @dateval and @datestr, but as it turns out, I didn't. Could please help me out?
Rgds,
Mårten
Re: dates in @elem
Postby EViews Gareth » Mon Feb 10, 2020 7:15 am
Remove the quotes in @elem
Bjellerup
Re: dates in @elem
Postby Bjellerup » Mon Feb 10, 2020 7:24 am
Thanks! Strange, I tried that earlier and it didn't work. Must have got it wrong in some other way I guess.
Bjellerup
Re: dates in @elem
Postby Bjellerup » Mon Feb 10, 2020 8:34 am
Hi again,
Later in the program I'm trying to create a loop that rolls one step forward at a time. Unfortunately, I don't get the date format right.
I'm trying something like (where %sobs and %fobs are defined earlier as "1993q1" and "2008q1")
for !i=1 to !nrolls step 1
%first=%sobs
%last=%fobs+!i
I suspect I need to tranform %fobs in the last line but I don't understand how. Do I mix string and scalar here?
Re: dates in @elem
Postby EViews Gareth » Mon Feb 10, 2020 8:40 am
Use the @dateadd function, or a mixture of @dtoo and @otod and @dateval/@datestr to convert from string to date to observation number and back again.
mamo
Re: dates in @elem
Postby mamo » Wed Feb 12, 2020 5:00 am
Depending on what you want to do with the rolling samples, you may also just enlarge the sample stepwise as follows
%sobs="1993Q1" %fobs="2008q1" !nrolls=10 for !i=1 to !nrolls step 1 smpl %sobs %fobs+!i ' do sth. here with the enlarged sample next
