Variance decomposition for eq02 is attached within workfile as table fi_coefvardecomp.
Somehow eviews displays coefficients (c1 to c5) rather than regressors themselves in the table.
How are we to determine multicoll between regressors with this table please comment.
Thank you
Panel data Coefficient Variance Decomposition Bug?
- panel coeffvardecomp_forum.wf1
- (82.12 KiB) Downloaded 637 times
Re: Panel data Coefficient Variance Decomposition Bug?
Your equation was specified by coefficient, not by regressors.
So how can i interpret the results any idea.
Match up C(1) with the C(1) in the equation output.
OK I matched it and then does it give me info on multicorrelation of c(1)'s regressor with other coefficient's regressors for example ?
I have one issue : as you can see from attached file eq02 on previous posts, the regression specification has coefficients (c(1) to c(5)) jointly multiplying the regressors. For example : (1-exp(c(1))@trend)*c(2)*(1-c(3))*LOG(Saving_rate*100)
Do you have any idea how are we to interpret the Variance Decomposition results within this setting ?
Thank you.
Thank you.
