Hi there,
I'm getting the following error message : "Equation or VAR specification is incomplete in "EQUATION
REERNFA_AU.ARDL(DEPLAGS=3, REGLAGS=3, FIXED) REERLN_AU NFA_AU TOTLN_AU"
When running the command: equation reernfa_au.ardl(deplags=3, reglags=3, fixed) reerln_au nfa_au totln_au
I've tried different things (i.e. declaring the equation before running the command) to no avail.
I'm using EViews 9.
Best regards.
ardl command - error message
Re: ardl command - error message
Works for me:
Is your copy of EViews up to date?
wfcreate m 1990 2020
series reerln_au=nrnd
series nfa_au=nrnd
series totln_au=nrnd
equation REERNFA_AU.ARDL(DEPLAGS=3, REGLAGS=3, FIXED) REERLN_AU NFA_AU TOTLN_AU
maragloria
Please ignore my post. I found the mistake. Many thanks!
maragloria
I should update to 9.5, right?
maragloria
Hello Gareth,
I've just updated to EViews 9.5. I noticed that, EViews 9.5 no longer readily provides the "adjustement speed" coefficient (CointEq(-1), EViews 9 manual II, p. 293). It was quite useful to have that. How can I get that coefficient with EViews 9.5?
Thanks again,
Mara
Thanks again,
Mara
You'll have to wait until the next patch which will re-enable it.
Dear SirYou'll have to wait until the next patch which will re-enable it.
When it is expected the rectify the modifications regarding the ECT in ARDL model. (next updated Patch)
