Panel data cointegration
Posted: Wed Apr 12, 2017 8:46 am
I am estimating causality between 4 variables in panel data and part of the process includes testing for cointegration. When I test for Johansen-Fisher cointegration through Quick>Group Statistics>Johansen Cointegration Test, I get different results from when I set-up a VAR with my 4 variables and then go to View>Cointegration test.
Is there a reason for which this is happening and if so, which output should I follow?
I am using EviewS 9. The two different outputs are attached.
Thank you for your help.
