Panel data cointegration
Miroupo
Postby Miroupo » Wed Apr 12, 2017 8:46 am
I am estimating causality between 4 variables in panel data and part of the process includes testing for cointegration. When I test for Johansen-Fisher cointegration through Quick>Group Statistics>Johansen Cointegration Test, I get different results from when I set-up a VAR with my 4 variables and then go to View>Cointegration test.
Is there a reason for which this is happening and if so, which output should I follow?
I am using EviewS 9. The two different outputs are attached.
Thank you for your help.
Group stat coint vs VAR coint.docx
(28.04 KiB) Downloaded 525 times
Re: Panel data cointegration
Postby EViews Gareth » Wed Apr 12, 2017 9:04 am
The VAR/VEC estimator and corresponding test is doing nothing panel related, whereas the group cointegration test is doing the panel version of the tests.
Miroupo
Postby Miroupo » Wed Apr 12, 2017 9:14 am
Therefore, I should follow the Group Statistics cointegration test.
Thank you for your reply!!!
