Tracking different samples with if statement
maragloria
Postby maragloria » Thu Mar 23, 2017 5:43 am
Hi there,
I wrote the following code to assign different values to matrix temp in different samples.
I would like some suggestions to simplify the if statement below:
%sample1 = "1999q1 2001q4" %sample2 = "2002q1 2004q4" for %1 %2 {%sample1} {%sample2} smpl {%1} {%2} %currsmpl = @pagesmpl 'get current sample string ss0 = @word(%currsmpl,1) 'only 1st element of sample is enough string ss1 = @word(%sample1,1) string ss2 = @word(%sample2,1) if @eqna(%ss0,%ss1) then matrix temp = mat01 else if @eqna(%ss0,%ss2) then matrix temp = mat02 endif endif next
Could I make the if statement simpler? Something like:
if %currsmpl = %sample1 then ...
I've tried different versions but to no avail:
if {%currsmpl} = {%sample1} then ...
if @eqna(%currsmpl,%sample1) then ...
Many thanks!
maragloria
Re: Tracking different samples with if statement
Postby maragloria » Thu Mar 23, 2017 8:22 am
Actually, the code I posted is not doing what I intend. Your help would be really appreciated. Thanks!
EViews Matt
Postby EViews Matt » Thu Mar 23, 2017 9:35 am
The immediate issue with your code is that you've created string objects (ss0, ss1, ss2) but later used string variables (%ss0, %ss1, %ss2). Those non-existant variables will be treated as NAs by @eqna, thus your first if statement conditional will always be true and temp will always be assigned mat01.
After fixing that issue, the next issue you'll find is that @pagesmpl returns an upper-case string while your sample strings are lower-case, thus none of your if statement conditionals will be true. That's easy to fix by changing the q's in your samples to Q's, or by using @upper elsewhere in your code.
However, regarding simplifying your code, there are some ways you could completely eliminate the if statements. If you'll always iterate through your samples in a consistent order you can make the assignment to temp dependent on an iteration number rather than the current sample. For example,
%sample1 = "1999Q1 2001q4" %sample2 = "2002Q1 2004q4" !i = 1 for %1 %2 {%sample1} {%sample2} %tmp = @str(!i, "i02") matrix temp = mat{%tmp} !i = !i + 1 next
The above code assumes that the matrices you're assigning from are regularly named (mat01, mat02, etc.), but you can just as easily use a list of arbitrary matrix names. For example,
%sample1 = "1999Q1 2001q4" %sample2 = "2002Q1 2004q4" %mats = "mat01 mat02" !i = 1 for %1 %2 {%sample1} {%sample2} %tmp = @word(%mats, !i) matrix temp = {%tmp} !i = !i + 1 next
There may be other, better ways to organize the for loop based on the work your program will perform, but the above are some starting points.
maragloria
Postby maragloria » Thu Mar 23, 2017 10:30 am
This is great! Thanks for all your suggestions.
