Hey,
I'd like to show some summary statistics for certain variables. The statistics I get by using the stats command are nice, but not sufficient. I'd like to add certain quantiles of the variables to the table. Is there any possibility to do this?
Thanks in advance!
Best,
Tuning the stats table (of a group object)
Re: Tuning the stats table (of a group object)
You could write a simple program that creates the table you want, then add it to your add-ins menu to make it available all the time.
The problem is, the code is for a workshop and using add-ins is always a bit of a problem.
I guess that means directly manipulating the table without create it all by myself isn't possible?
You can freeze and name the stats table, and then add new elements to the frozen table.
Thanks, I'll try that!
