Direct transformations of db referenced series
Posted: Fri Feb 17, 2017 4:31 am
by mamo
Dear Eviews team
I use Eviews 9.5 March 17 2016 build.
Are direct transformations of series stored in a database, such as
show d(dbn::x)
meant to be feasible in Eviews?
If so I am wondering about an unexpected result in circurmstances similar to the ones generated by the programme below.
In short, it seems that
show d(db1::x) d(db2::x)
unexpectedly shows d(db1::x) in both columns.
In contrast
show (db1::x) (db2::x)
works as expected.
What is wrong here?
Best, mamo
Example code
' Create two wfs, testdb1 and testdb2, to be used as dbs later on wfcreate(wf=testdb1) a 2000 2015 series x=0 smpl @first+1 @last series x=x(-1)+1 smpl @all wfsave testdb1 wfclose testdb1 wfcreate(wf=testdb2) a 2000 2015 series x=0 smpl @first+1 @last series x=x(-1)+2 smpl @all wfsave testdb2 wfclose testdb2 ' Assign handles to wf names db testdb1.wf1 as db1 db testdb2.wf1 as db2 ' Create new wf wfcreate a 2000 2015 ' unexpectedly, the 2nd column does not show 1st differences ' of x taken from test2, but rather taken from test1 show d( db1::x ) d(db2::x) ' In contrast, showing series from dbs without transformation ' works as expected ' show db1::x db2::x
Re: Direct transformations of db referenced series
Posted: Fri Feb 17, 2017 5:04 am
It is supposed to work, and does, I think. When I ran your code, I received the expected result.
Posted: Fri Feb 17, 2017 5:26 am
i.e.
Posted: Fri Feb 17, 2017 5:34 am
by mamo
indeed, it works as intended if the name of the working directory does not contain spaces (like "c:\temp" as in your example).
Otherwise, the result I have reported can be replicated.
The code below is the same as before, except the 2nd line which changes to a working directory with a "spacy" name.
Best,
mamo
' Change to a directory with spaces in the name cd "C:\temp\This is a test dir" ' Create two wfs, testdb1 and testdb2, to be used as dbs later on wfcreate(wf=testdb1) a 2000 2015 series x=0 smpl @first+1 @last series x=x(-1)+1 smpl @all wfsave testdb1 wfclose testdb1 wfcreate(wf=testdb2) a 2000 2015 series x=0 smpl @first+1 @last series x=x(-1)+2 smpl @all wfsave testdb2 wfclose testdb2 ' Assign handles to wf names db testdb1.wf1 as db1 db testdb2.wf1 as db2 ' Create new wf wfcreate a 2000 2015 ' unexpectedly, the 2nd column does not show 1st differences ' of x taken from test2, but rather taken from test1 show d( db1::x ) d(db2::x) ' In contrast, showing series from dbs without transformation ' works as expected ' show db1::x db2::x
Posted: Fri Feb 17, 2017 5:40 am
ok, we'll fix.
