I am using EViews 9.1 and the add-in that generates LaTex Code from a table.
I'm not satisfied with the way this add-on generates the output, my main issue being that it generates a linebreak after each entry, resulting in a terribly long texcode. I would therefore like to personalize the add-in. It seems to me that the .append command forces a line break. My question is: is there an alternative command that allows to append text without breaking the line?
I appreciate all the help!
.append without linebreak
Re: .append without linebreak
There is not.
However you might be able to concatenate lines in the program before appending them to the text object.
Thus:
would change to
Thus:
{%tablename}.append this is some
{%tablename}.append text that is added
{%tablename}.append this is some text that is added
Thanks. I have a follow-up question:
I found the new feature that when copying a table, one can choose latex code instead of text.
However, even for the simplest, say 2x2 table with numbers, the resulting tex code is cumbersome by putting each entry in a multi-column environment. Any thoughts why that is the case? Otherwise, this copy command would be such a great feature!
EViews Rebecca
The multicolumn environment is there to accommodate complex tables, such as regression output that includes headings and summary statistics.
