Extract path
KrilleJ
Extract path
Postby KrilleJ » Fri Jan 13, 2017 8:00 am
Is there any convenient (pre-built) way to extract the path part of a string that is returned from uifiledlg?
That is, from
@uifiledlg(%myFile, "prg", "open")
could I extract the path part of %myFile and separate it from the file part?
Best,
Kristian
Edit:
The current clunky solution that I have is:
%pureFileName="" for !currPos=1 to @length(%myFile) if @mid(%myFile, !currPos, 1)="\" then %pureFileName="" else %pureFileName=%pureFileName + @mid(%myFile, !currPos, 1) endif next string file=%pureFileName string Path=@replace(%myFile, %pureFileName, "")
Any smoother way is very welcome.
Re: Extract path
Postby EViews Gareth » Fri Jan 13, 2017 8:40 am
No, but you can improve the klunkiness by using the @instr function
