I am trying to save the cointegration relationships from a VECM using makecoint as in the capture screen but the program crashes every time. I am using eViews 9. Do you know the reason? Alternatively, how can I save the cointegration relationships from a vecm?
{%var}.makecoint
Thanks a lot in advance,
Marta
Saving cointegration relationships from VECM
Re: Saving cointegration relationships from VECM
Thanks, I had been following these instructions already.
Please see the workfile and program. I can run the makecoint line from the command window and I have no issues. However, when I run in from the program, eViews breaks down.
_var_us.makecoint
Regards,
Marta
_var_us.makecoint
Regards,
Marta
- makecoint.prg
- Program estimates a VECM and tries to save cointegration relationships
- (798 Bytes) Downloaded 469 times
- dataset_dec16.wf1
- (383.03 KiB) Downloaded 320 times
You need to provide a group name.
Thanks, that worked.
EViews Matt
The crash when omitting the group name within a program will be fixed in the next EViews patch.
