Eviews crashes: @spec command
Postby tvonbrasch » Tue Dec 13, 2016 1:15 am
Eviews crashes when I run the attached program,
I believe the problem relates to using the model.@spec command after having replaced a variable in a model object:
model.replacevar x y string a=model.@spec("y")
can you please take a look at it?
snu_modellen_control_q6_konsum_manuelt.prg
(839 Bytes) Downloaded 326 times
Re: Eviews crashes: @spec command
Postby tvonbrasch » Tue Dec 13, 2016 1:42 am
When trying the code some more, it looks like the problem with the @spec command relates to using a copied model. If i run the command
the code works, but if I run the code
copy model model2 string a=model2.@spec("y")[
Eviews crashes....
T
Postby EViews Gareth » Tue Dec 13, 2016 8:45 am
Will be fixed next patch.
