Multi-Line Programming
fmgoto
Postby fmgoto » Thu Jan 14, 2010 1:55 pm
I wonder if it is possible to write two commands in the same line. For the sake of "readability" only. Codes are getting too long. Thanks.
Re: Multi-Line Programming
Postby EViews Gareth » Thu Jan 14, 2010 2:01 pm
You cannot write two commands on the same line.
You can, however, write one command on two lines, by using the line continuation character " _ "
fmgoto
Postby fmgoto » Fri Jan 15, 2010 7:39 am
That would be a nice feature for a future version! It helps a lot when you need to define multi-dimensional objects! Thanks, Fabio
PS: Gareth, it also seems that when you write multi-line commands with "_", tabs and comments should not be used after the "_" symbol. Is that right?
Postby EViews Gareth » Fri Jan 15, 2010 8:16 am
Literally all the _ symbol does is tell EViews to read two lines as one. Since you cannot have comments in the middle of a line in EViews (which would be a nice feature for us to add), you cannot have comments after a _
