Area Band
Burak
Area Band
Postby Burak » Wed Nov 09, 2016 11:04 am
Hello, I am tring to show my impulse responses with 68% and 95% confidence intervals. I created matrix including all the values and I am using area band graph to show them. My matrix has 10 rows and 5 columns. First 2 columns are 95%, 3rd-4th columns are 68% confidence intervals and last column is mean response. When I use area band I see the confidence intervals but for some reason last column, mean response, does not show up in the graph. I couldn't find any option in the graph to correct it. Possibly, it is invisible under the shaded area. I am looking for help how to correct it. You can see my graph as attached. C5 is my last column, mean responses.
Thank you.
Re: Area Band
Postby EViews Jason » Wed Nov 09, 2016 4:22 pm
Create a mixed graph instead of the area band graph. In the 'Mixed Settings' tab, set the first 4 columns to area bands and the 5th column to a line graph.
