ASCII Read and skipcol
Posted: Tue Nov 01, 2016 7:53 am
A quick question - when using the Read command for an ASCII file, I can use skipcol=n option to ignore the first n columns in the file. Is there anyway to get EViews to ignore the nth column out of N (e.g. the 5th column out of 10)? I suspect not, but wanted to check as the alternatives will be less efficient computationally.
