Panel Data World Values Survey
mbelgie
Postby mbelgie » Wed Oct 19, 2016 2:22 pm
Dear All,
I want to estimate a panel regression model using the World Values Survey.
The WVS is collected in 5 yearly waves so the data which is available (which I am using) is from 2005-2009 and 2010-2014.
My Independent variable are GDP, Trade Openness and Gross Capital formation which are available yearly. I have a dataset for 64 countries.
How should I manage the different frequency of data i.e. yearly independent data and the five yearly wave data?
How should I input the five yearly wave data against the annual data for my panel regression?
Thank you.
jmagomez
Re: Panel Data World Values Survey
Postby jmagomez » Wed Oct 19, 2016 5:23 pm
Dear mbelgie,
Could I see these data? I do not know what is the World Values Survey. Maybe I can help you.
Best Regards, Jmagomez.
mbelgie
Postby mbelgie » Thu Oct 20, 2016 3:07 pm
thank you for your response.
I am posting a link to WVS website.
http://www.worldvaluessurvey.org/WVSOnline.jsp
From this survey, I have used data on certain questions.
jmagomez
Postby jmagomez » Fri Oct 21, 2016 9:21 am
Dear mbelgie,
I think you should transform the wave data into annual data. The problem is: how could the interpolation be done?
You may use more waves to make a better interpolation and analysis.
Best Regards.
mbelgie
Postby mbelgie » Fri Oct 21, 2016 11:38 am
Dear Jmagomez,
Thank you for your response.
Do you think I can use a mean value for the years for the wave data? Could that be a way of managing interpolation?
jmagomez
Postby jmagomez » Mon Oct 24, 2016 3:45 am
Dear mbelgie,
Yes, I believe you would be taking a good technique to adapt the data available. But as I said, I think you should use a longer period than two waves.
Regards.
mbelgie
Postby mbelgie » Sat Nov 12, 2016 4:13 pm
Dear jmagomez,
Thank you for the reply. I have used the same value of the WVS for the rest of the reported wave years. So if it says 25 % for 1999 to 2004 wave, I have used the 25% for all these years.
Now I am trying to build the model.
Thank you again for the help.
