Unrestricted BEKK GARCH
manfrycar
Postby manfrycar » Wed Oct 12, 2016 8:08 am
Hi all,
I've searched for a solution in many posts but I could not find it. I really need to solve this issue in order to finish my final dissertation. I'm trying to run a bivariate BEKK GARCH with volatility spillovers. But, this error message appears: Missing values in @LOGL series at current coefficients at observation 8/25/2010 in "DO_ BVGARCH.ML(SHOWOPTS, M=1000, C=1E-5)". I'm using Eviews 9.5 . Can you please check my program?
smpl @all series y1 = d(log(cno)) series y2 = d(log(cnh)) ' set sample ' first observation of s1 need to be one or two periods after ' the first observation of s0 sample s0 08/24/2010 08/31/2016 sample s1 08/25/2010 08/31/2016 ' initialization of parameters and starting values ' change below only to change the specification of model smpl s0 'get starting values from univariate GARCH equation eq1.arch(m=1000,c=1e-5) y1 c y1(-1) y2(-1) equation eq2.arch(m=1000,c=1e-5) y2 c y1(-1) y2(-1) ' declare coef vectors to use in bi-variate GARCH model ' see above for details coef(2) mu mu(1) = eq1.c(1) mu(2) = eq2.c(1) coef(4) lag lag(1) = eq1.c(2) lag(2) = eq1.c(3) lag(3) = eq2.c(2) lag(4) = eq2.c(3) coef(3) omega omega(1)=(eq1.c(4))^.5 omega(2)=(eq2.c(4))^.5 omega(3)=0 coef(4) alpha alpha(1) = (eq1.c(5))^.5 alpha(2) = (eq2.c(5))^.5 alpha(3) = 0 alpha(4) = 0 coef(4) beta beta(1) = (eq1.c(6))^.5 beta(2) = (eq2.c(6))^.5 beta(3) = 0 beta(4) = 0 ' constant adjustment for log likelihood !mlog2pi = 2*log(2*@acos(-1)) ' use var-cov of sample in "s1" as starting value of variance-covariance matrix series cov_y1y2 = @cov(y1, y2) series var_y1 = @var(y1) series var_y2 = @var(y2) series sqres1 = (y1-mu(1)-lag(1)*y1(-1)-lag(2)*y2(-1))^2 series sqres2 = (y2-mu(2)-lag(3)*y1(-1)-lag(4)*y2(-1))^2 series res1res2 =(y1-mu(1)-lag(1)*y1(-1)-lag(2)*y2(-1))*(y2-mu(2)-lag(3)*y1(-1)-lag(4)*y2(-1)) ' ........................................................... ' LOG LIKELIHOOD ' set up the likelihood ' 1) open a new blank likelihood object (L.O.) name bvgarch ' 2) specify the log likelihood model by append ' ........................................................... logl bvgarch bvgarch.append @logl logl bvgarch.append sqres1 = (y1-mu(1)-lag(1)*y1(-1)-lag(2)*y2(-1))^2 bvgarch.append sqres2 = (y2-mu(2)-lag(3)*y1(-1)-lag(4)*y2(-1))^2 bvgarch.append res1res2 = (y1-mu(1)-lag(1)*y1(-1)-lag(2)*y2(-1))*(y2-mu(2)-lag(3)*y1(-1)-lag(4)*y2(-1)) ' calculate the variance and covariance series bvgarch.append var_y1 = omega(1)^2 + omega(3)^2 + alpha(1)^2*sqres1(-1) + alpha(2)^2*sqres2(-1) + alpha(1)*alpha(2)*res1res2(-1) + beta(1)^2*var_y1(-1) + beta(2)^2*var_y2(-1) + beta(1)*beta(2)*cov_y1y2(-1) bvgarch.append var_y2 = omega(2)^2 + alpha(3)^2*sqres1(-1) + alpha(4)^2*sqres2(-1) + alpha(3)*alpha(4)*res1res2(-1) + beta(3)^2*var_y1(-1) + beta(4)^2*var_y2(-1) + beta(3)*beta(4)*cov_y1y2(-1) bvgarch.append cov_y1y2 = omega(2)*omega(3) + alpha(1)*alpha(2)*sqres1(-1) + alpha(3)*alpha(4)*sqres2(-1) + (alpha(1)*alpha(4) + alpha(2)*alpha(3))*res1res2(-1) + beta(1)*beta(2)*var_y1(-1) + beta(3)*beta(4)*var_y2(-1) + (beta(1)*beta(4) + beta(2)*beta(3))*cov_y1y2(-1) ' determinant of the variance-covariance matrix bvgarch.append deth = var_y1*var_y2 - cov_y1y2^2 ' inverse elements of the variance-covariance matrix bvgarch.append invh2 = var_y2/deth bvgarch.append invh1 = var_y1/deth bvgarch.append invh3 = -cov_y1y2/deth ' log-likelihood series bvgarch.append logl =-0.5*(!mlog2pi + (invh1*sqres1 + 2*invh3*res1res2 + invh2*sqres2) + log(deth)) ' remove some of the intermediary series bvgarch.append @temp invh1 invh2 invh3 sqres1 sqres2 res1res2 deth ' estimate the model smpl s1 bvgarch.ml(showopts, m=1000, c=1e-5) ' change below to display different output show bvgarch.output graph varcov.line var_y1 var_y2 cov_y1y2 show varcov
bbb.prg
(3.43 KiB) Downloaded 368 times
aaa.wf1
(57.72 KiB) Downloaded 326 times
