Error messages from programs with loops
Posted: Thu Oct 06, 2016 3:08 pm
by LindaR
I am using a loop to decompose multiple time series (using X13.SEATS) with permissible errors set to 1000 so it runs through all the series. For almost all the error messages I get in the program log the series are identified as SER{!I} is it possible to capture the actual series number(s)?
Re: Error messages from programs with loops
Posted: Thu Oct 06, 2016 3:22 pm
Hard to say without knowing exactly what you are doing
Posted: Thu Oct 06, 2016 3:27 pm
by LindaR
Would sending you the program and an example of the program log help?
Posted: Thu Oct 06, 2016 4:55 pm
Probably.
Posted: Thu Oct 06, 2016 6:02 pm
by LindaR
Hope so,the code and the program log are attached as is the final error message. The specs referenced in the program are at the end of the error message.
Posted: Fri Oct 07, 2016 5:30 am
I can see no reason why EViews isn't reporting the series name, rather than ser{!i}, which is weird.
But I guess you could force it by recording it yourself. Off the top of my head, I think I would do something like:
!errcount = @errorcount 'the x13 line here !errcount2 = @errorcount if !errcount2>!errcount then logmsg !i endif
And put a logmode +logmsg somewhere at the top.
Posted: Sun Oct 09, 2016 11:37 pm
by LindaR
Thanks Gareth, your suggestion worked - I now know which series are failing and why/how. All the best, Linda
