Attached is a subroutine to carry out a robust regression analysis in EViews. I am sure the following code can be modified in a much more elegant way, especially with the new programming features of the version 7. However, it would be nice to see this type of analysis, or preferably a more comprehensive version of it, as an additional tool in EV7. Once implemented, robust regression procedures can later be combined with those of quantile regression under a more general name.
This program requires EViews 7 or later
'Robust Regression
'Reference: Adapted from the MATLAB code written by James P. LeSage, Dept of Economics, University of Toledo. Original version of the code is available at: http://www.spatial-econometrics.com/regress/robust.m
call robustreg
subroutine robustreg
'The following objects will be created through the program.
'If necessary, assign different names to avoid overwriting.
%coef = "beta"
%eq1 = "ols"
%eq2 = "itrw"
%table = "output"
%ser = "weight"
%resid = "resw"
!result = 0
'Get the names of variables directly from the user.
@uidialog("edit",%depname,"Enter the name of the dependent variable","edit",%indepname,"Enter a list of independent variables (can include group names)")
if !result=-1 then
stop
endif
'Select an appropriate method for the weighting function
!choice = 1
%list = "Tukey(default) Huber Ramsay Andrew"
!result = @uiradio(!choice, "Weighting Function Choice", %list)
if !result=-1 then
stop
endif
%choice = @word(%list,!choice)
group robustindependents {%indepname}
%indepname = "robustindependents"
'Determine the number of independent variables.
!n = {%indepname}.@count
'Construct a table to store the results
table(4+!n,5) {%table}
{%table}.setwidth(1:5) 10
{%table}.setlines(a2:e2) +d
{%table}.setlines(a4:e4) +d
{%table}.setformat(D) f.5
{%table}(3,1)= "Variable"
{%table}(3,2)= "Coefficient"
{%table}(3,3)= "t-Statistic"
{%table}(3,4)= "Prob."
{%table}(3,5)= "R-squared"
for !v = 1 to !n
{%table}(4+!v,1) = {%indepname}.@seriesname(!v)
'Find starting values
equation {%eq1}.ls {%depname} {%indepname}
vector {%coef} = @subextract(c,1,1,!n,1)
series {%resid} = resid
!wparm = 2*({%eq1}.@se)^2 'weighting parameter
!scale = @median(@abs({%resid} - @median({%resid})))/.6745 'scale parameter
'Initialize series and control variables
series {%ser} =1
group {%indepname}star
vector(!n) {%coef}0
!tol=1
!count=0
'Start the loop
while !tol >.00001
{%coef}0 = {%coef}
{%resid} = {%resid}/!scale
!count=!count+1
if !choice= 1 then
{%table}(1,1)= "Tukey's biweight"
{%ser}=(1-({%resid}/!wparm)^2)^2
{%ser}=@recode({%resid}=0,1,@recode(@abs({%resid})>!wparm,0,{%ser}))
else if !choice = 2 then
{%table}(1,1)= "Huber's t function"
{%ser} = !wparm/@abs({%resid})
{%ser} = @recode(@abs({%resid})<=!wparm,1,{%ser})
else if !choice = 3 then
{%table}(1,1)= "Ramsay's E function"
{%ser} = @exp(-!wparm*@abs({%resid}))
{%ser} = @recode({%resid}=0,1,{%ser})
else if !choice = 4 then
{%table}(1,1)= "Andrew's wave function"
{%ser} = @sin({%resid}/!wparm)/({%resid}/!wparm)
{%ser} = @recode({%resid}=0,1,@recode({%resid}>@acos(-1)*!wparm,0,{%ser}))
endif
endif
endif
endif
'Weighted least squares
series {%depname}star = {%depname}*@sqrt({%ser})
for !i=1 to !n
series {%indepname}star!i = {%indepname}(!i)*@sqrt({%ser})
{%indepname}star.add {%indepname}star!i
series {%depname}hat=0
equation {%eq2}.ls {%depname}star {%indepname}star
for !j=1 to !n
{%depname}hat = {%depname}hat+{%coef}(!j)*{%indepname}(!j)
{%resid} = {%depname}-{%depname}hat
'Recalculate the tolerance level
!tol = @max(@ediv(@abs({%coef}-{%coef}0),@abs({%coef}0)))
wend
'Generate some basic equation output (can be extended further)
stom({%indepname}star,{%indepname}m)
!evar = @sumsq({%resid})/(@obs({%depname})-!n)
vector {%coef}sig = @sqrt(!evar*@getmaindiagonal(@inverse(@transpose({%indepname}m)*{%indepname}m)))
vector {%coef}t= @ediv({%coef},{%coef}sig)
'Store the generated output values into the table
for !v=1 to !n
{%table}(4+!v,2) = {%coef}(!v)
{%table}(4+!v,3) = {%coef}t(!v)
{%table}(4+!v,4) = @tdist({%coef}t(!v),@obs({%depname})-!n)
{%table}(5,5) = 1-(@sumsq({%resid})/@sumsq({%depname}-@mean({%depname})))
'Final wrap-up
delete {%coef}0 {%coef}t {%coef}sig {%eq2} {%indepname}m {%indepname}star* {%depname}hat {%depname}star robustindependents
show {%table}
endsub
