Opening text files from Google Drive
Postby tvonbrasch » Wed Aug 31, 2016 7:03 am
after the update, Eviews crashes when I try to open a text file from Google Drive
opening text file from google docs.JPG (99.29 KiB) Viewed 5919 times
can you fix this?
Re: Opening text files from Google Drive
Postby EViews Jason » Wed Aug 31, 2016 2:17 pm
Postby tvonbrasch » Thu Sep 01, 2016 11:02 pm
thanks,
it is a bit strange, but when opening Google Drive from within Eviews, it shows files that I deleted from Google Drive weeks ago. Compare the pictures:
Maybe this is a related issue?
Postby EViews Jason » Fri Sep 02, 2016 8:51 am
That is correct. Google drive permits files with the same name. 'Deleting'' doesnt actually delete it. It tags the file as hidden. EViews however cannot differentiate between hidden and non-hidden files
EViews has issues with files of the same name. We are working on that as well but it wont be in the next patch.
Postby tvonbrasch » Fri Sep 02, 2016 10:38 pm
okey, thanks for this information. good luck on fixing it.
